Disclaimer: This review was written as part of the We Love Testing program here. I received one Soundcore Zero to review and compare as part of a testing plan to my existing dual SoundCore Flare setup.
Product Links
Key Features
- 60 watt Hi-Res audio output from dual woofers, tweeters & passive radiators designed by ScanSpeak
- Bluetooth 5.0 supporting HFP, A2DP, AVRCP and multi-point play
- Internal 6700 mAh Battery for up to 10hrs playback depending on volume level (& to some extent content type)
- 3hr charge time via the 15V / 3A 5mm charger
- Built in microphone for hand free calls
- Auxiliary input
- Built-in & App controls for Power (On/Off), Play/Pause, Vol Up/Down, Bluetooth & BassUP control
- True Wireless Stereo capabilities with pairing to another SoundCore Zero
- IPX5 Waterproof rating - covering average splashes and sprays, just don’t submerge…
The Good (very good)
- Very Impressive audio and bass, especially with high bitrate content like 24bit live albums
- Good battery life
- Multi-point play support for x2 BT audio sources
- Improved access flap for power & auxiliary, no more fighting like the SoundCore Flare
- App control with user set power save settings
- Ability to pair with another Zero speaker for true left/right stereo playback
- Water resistance (splash-proof) - good for accidents or areas with children…
Not so good
- Another charging standard, a 5mm connector much like a non-USB-C laptop…surely USB-C would have been a sound choice?
- loss of full omnidirectional audio like the Flare…the Zero returns to the previous directional output of other SoundCore speakers with bass prominent from the rear…impairs audio a touch, depending on seated location, if used centrally in the room…
- No included manual (full specs and controls)
only a quick start guide
