Hello, a few days ago I received the SOUNDCORE Wakey from ANKER, I want to share my review about this device.
In this review I will make my comments about I consider to be the most important points.
Let us begin
Wireless Speed charging
The first thing I want to comment on is wireless charging, I definitely think that ANKER has the best wired and wireless mobile charging technologies, if they are not the best, they are definitely among the best.
The speed of charge: Really the charge is extremely fast, we are talking about you can charge your mobile in less than 30 minutes. Amazing.
In addition, has 2 USB connectors on the back to connect your mobile via cable.
You can charge your mobile via USB cable while using wireless charging, and apparently this does not degrade the speed of the charge.
Obviously, it has the integrated IQ technology for devices up to 10W.
From 1 to 10, I definitely give it a 10 when it comes to wireless charging.
Sound
SOUNDCORE Wakey has a clean, high quality sound, it sounds perfectly in indoor environments, very good for 10W, volume you do not experience bad sound if you use the highest, Wakey have the âWhite noise generatorâ technology.
It also has 10 environmental sounds to induce sleep, this is interesting for me, and relaxing, Really is very interesting for me.
It has FM Radio, and you can pre-set up to 10 favorite stations for quick access.
From 1 to 10, I give it 10 in sound quality, it sounds perfectly for 10w
Connection
Wakey has Bluetooth 5 with all its advantages, speed, range of coverage,
In my test, the bluetooth worked perfectly in a range of 11m to 20m indoors.
It has a connector for aux, in case you want to connect a device that does not use bluetooth.
Clock and alarm clock
I will start by giving my score. From 1 to 10, I give 12. LOL
The time is set inmedialtly when you synchronize your mobile.
The Wakey has a Led screen with a very nice design. You can modify the brightness level of the clockâs LED display, It even has a sensor that allows the brightness to adjust automatically depending on the amount of light in the room. Interesting because it is an alarm clock, it will be in your room while you sleep, light should not be a problem.
Even if you want you can turn off the screen.
You can add up to 15 alarms for different hours, and the best thing is that you do it from the application, you have 10 tone options for your alarms including the same FM radio.
It also has a range of sounds that induce sleep. Wow. Great.
Buttons and Controls
The control is completely easy to handle, with a good touch sensitivity, just place your finger.
The control panel are quite intuitive.
It also includes a very high quality microphone
Design and Size
As you can see in the images below, the design is very elegant, and the size is very similar to the alarm clocks, around 7 inches long.
Matte finish, it does not break with the design of your room because color is white.
It has an adequate weight, around one pound.
The packaging is well designed, protects the equipment from damages.
Userâs manual
Userâs manual in 17 different languages, very easy to understand, intuitive.
Price
It is currently available in Amazon for only $ 99, which is a considerably low price, because you have about 5 different devices in one
https://www.amazon.com/dp/B07NNR1JH5/?tag=cm-sales-us-2019-20
Disadvantages
Disadvantages
⢠That must always be connected to the electric power to work, I am sure that ANKER launches a model that allows charging.
⢠For the FM radio to work, you have to connect a cable that works as an antenna, I do not know if you have built an internal antenna without external cable.
Below I leave you the photos and the video of the unboxing. Donât forget view the youtube video.
This is the perfect combination, wireless speed charging, speakers, alarm clock.
DEFINITELY AN EXCELENTE COMBINATION
Your bedside table have one or two charger, cables, alarm clock, speaker, your mobile.
I HAVE SOUNDCORE WAKEY.
https://www.youtube.com/watch?v=ajNIQpoJ8pI
