Soundcore life note auto connect
Earbuds had been used with iPhone 11 and iPad. Suddenly when removed from box they won’t auto connect to any device.
I’ve done the reset procedure and the lights blink like they are suppose. Also removed devices from the iPhone and re-paired… nothing changes the problem.
Only way to get connection is to hit pair in the iPhone Bluetooth settings right when the buds are removed from the box. If you try this after the earbuds have completed their sound sequence they won’t connect at all.
Any way to fix this.
  • Forget the pairing record on your device and turn off the Bluetooth on your device
  • Place the earbuds into the charging case and make sure they are being charged.
  • Press and hold the button on both earbuds for 3 seconds. The LED indicators will flash red 3 times and then turn white.
  • Close the charging case, wait for several minutes and then take them out of the charging case, the white light on one side will flash quickly, which means it enters pairing mode
  • Enable the Bluetooth on your phone. You can find the device name "Soundcore Life Note " or “Soundcore Life Note-L” on the Bluetooth list.
  • Please click "Soundcore Life Note " or “Soundcore Life Note-L” for pairing, the white light will flash slowly, which means it paired successfully.
  • Then there will pop out a screen with “Bluetooth Pairing Request”, just click “Pair” (this step is very important)
Please note, due to the chips platform’s compatibility, in the bluetooth pairing list the Soundcore Life Note is displayed as “connected”, and the Soundcore Life Note-L is displayed as “not connected”. In fact, the earbuds are normally TWS paired to work
Good morning. For weeks I was very stressed due to I was unable to have the earbuds connected. This morning I follow your instructions, waited patiently, and succeded! Thank you.
Thanks , it’s working for me :sunglasses::partying_face:
Its not working for me, Plz help me to resolve the same
Thanks
