Check this out…
Hackers could potentially steal sensitive information.
Check this out…
Good thing I don’t have any smart bulbs
I only have LED dumb bulbs.
I wish the hackers all the best in trying to hack those!
Unfortunately the world we live and work in opens us up to online vulnerabilities and it’s just something we accept for the sheer convenience of living an on demand everything at the click of a button life.
This is why you connect WiFi bulbs to your Guest WiFi and not the main network.
The “S” in IoT is for security…
Good article… this can happen / is possible with ANY Internet connected device, does not need to be a smart bulb… IoT devices are highly susceptible to hacking.
Smart Plugs, Smart Bulbs, Smart Assistants, Smart Phone, Dumb Us
We do the same. But didnt use guest. We get our new router I plan on doing that way.
We use a seperate network for our smart devices as well. This network has no access to our main network.
Same here, our main router handles everything online while our secondary one handles the smart devices with limited outbound access
All like minds, secondary router with DNS Controlled for outbound and limited bandwidth for all the IoT devices is what I use!
Great rest
Thanks for sharing !
Great idea hope that resolves some issues
How do you do that? Do you need to separate routers ?
Well it’s easier to use a separate guest network, almost every router has the option to allow guest access in the settings…and then you can limit outbound access.
Using a separate router like I do is a little bit harder
Most wireles routers have a Guest network. Refer to the Manual to set it up and create a password for it. Have your bulbs and other smart devices to that.
RoboVacs with WIFI !
(Willy has no.)
sorry to say I no smart lights but my light bulb are bright though. lol.
The heat generated from the torch is sufficient to drive away the hackers
Yes, I’m aware but never used it. Will set it up this weekend and switch all my smart gadgets to Guest. I think I can have the wifi not broadcast the SSID.
