Anker Soundcore Life Q10 Bluetooth Connection Error
Hello,
I bought a Monster computer. Although the computer sees my Anker Soundcore Life Q10 headset as a device in bluetooth, it cannot connect. So I couldn’t even pair the headset. I updated the drivers on this problem and said solutions in the community. However, I could not reach any conclusions. The headset connects to different phones and windows 10 devices. There is no problem with the headset.
I will be happy if you can help.
Yours truly.
discussion link:
https://answers.microsoft.com/tr-tr/windows/forum/windows_10-hardware/windows-10-bilgisayarım-güncel-model/ebac2fc3-880b-455f-b691-e95e4bb5f37b?messageId=3537026a-3c64-4cc1-ac01-d9eac8edb7e6&page=1
  • Confirm the headphones are fully charged (the indicator will charge until it’s a steady blue)
  • “Forget” the headphones in your device’s Bluetooth history
  • Reset the headphones by holding down MFB and V+ 5S when insert USB charger
  • Ensure there are no physical objects hindering the Bluetooth connection from the headphones to the device they’re connected to (such as a doorway or wall…even in a pocket can cause interference)
