The stream on Alexa stops after approx. 6 minutes. This is annoying because I use it also as babycam. Can this be changed?
Will EufyCam support Alexa?
it doesnt work with Alexa for routines. The integration is really a shame. I want to be able to create an action if there is motion detected by the device.
Any plan to add motion detection to alexa Ankersupport ?
Coming from Ring I missed this feature where it can be integrated with my other smart devices through Routines.
