Which set of Anker products should I get?
aw, I wish I would have seen this earlier, oh well, you would be saving yourself money and you would get better/newer products. Sry
Oh yeah not for the macs, but for @Pat_Legend , who only mentioned the phones in the OP, it would work. I like my Anker Speed 20000 for powering my laptop at 30w. it comes with the wall charger and c to c cable too.
It’s 'spensive though.
what coupon are you using for the Powerline II Lightning Cable?
Oh man I’m definitely gonna try to get the PowerCore Fusion 5000 before my next trip. So I’m gonna keep an eye on it
It should be the 3rd deal. :slight_smile:
The first link is to the 49.5w charger with 30w/usb-c and 19.5w usb and is $27.74 with adapter, the second link is actually only 42w charger with 30w/usb-c and 12w/usb and is $25.99 with no adapter and 7.5w less usb output.
What makes it Bad is Amazon linking the second unit as a New version to the white 49.5w charger which is actually 42w unit, But the Black 49.5w charger New version link is to the White 49.5w charger with adapter, which is a little misleading and could possibly be missed by some folks.
Mark
Right. It’s sooo confusing. One just seems to have a higher wattage. I dunno amazon linking things as ā€œnewer versionā€ is bs
Which cable exactly? Install coupon cabin or honey and they will auto add coupons at checkout
I wouldn’t bother buying one, I would pre order the C to lightning.
Ordered the C to Lightning, can’t wait to get it, I’m also getting the powercore speed PD which includes a USB C adapter. This is going to be my new set for my XS Max
@Chris_Renshaw
USB-C to Lightning is great, but I am always worried that I would lose charging and data transfer speeds when using an adaptor. My laptop, work computer, and power banks all have the standard USB port. I’m considering stocking up on a few USB-C to lightning cables just in case they go out of stock and disappear from Anker’s market, but I don’t see myself updating my computing devices and power banks within the next year.
I’d like to hear your view on this. Would you recommend hoarding cables that won’t be used anytime soon? Do you have any info on reduced speeds from using USB to USB-C adaptors to connect to the USB-C to Lightning?
Side note: I’m an iPhone user.
