Hello there, I bought the Wakey for myself and for my mother about 2 years ago (Summer 2019), I am in love with it. Just a couple of days ago (October 2021), I bought a couple more; a Black for my office (work) and White for my sister.
I was really shocked to see the brightness to be extremely dim to the point you barely see text on highest setting. I took it home to compare it with the one I got in 2019, and you can see the the difference in Brightness. The White one was matching my old black one but the issue is with the new black.
note: Top is Old and Bottom is new. Both are set on MAX brightness (manually). I also noticed that the symbols/icons printed on the Wakey unit are more brighter in the new one vs old one.
I see your unit had extremely bright LED like a flash light (you cannot see the LED dots), in my case its extremely dim that if you look at it in a slight angle you cannot see any text at all and if you set lowest brightness you barely see any light.
I took it to the Authorized dealer, they did open two additional units (a white one and a black one), checked the brightness which matched the too dim one. I left the Wakey for their workshop to figure why its very dim, if they cannot figure it out I will sadly return and refund it.
I am not sure if a feedback here would be useful to: 1- Point out if there was any changes in the LED/Brightness setting or design or simply a flaw in LED choice. and; 2- to suggest to make it with a wider range of brightness with ability to set range or category as (bedroom/office) to auto adjust the brightness. Maybe in the future design.
Anyways, I’m waiting on workshop reply. I really hope they manage to fix this brightness issue.
