All opinions and recommendations in this buying guide are my own and not affiliated with Anker.
For Android Users
PowerDrive III Duo
Anker’s latest car charger features dual PowerIQ 3.0 ports, which makes PowerDrive III Duo ideal for devices that support Qualcomm Quick Charge. However, because each port has a maximum output of 18W, this is unfortunately incapable of charging most notebooks.
- Amazon.com
- Amazon.ca
- Amazon.de
- Amazon.co.uk
- Amazon.fr
- Amazon.es
- Amazon.it
For Ultrabook Users
PowerDrive Speed+ Duo
A 30W PD port makes PowerDrive Speed+ Duo easy to recommend to not only ultrabook users, but iPad owners as well. In addition, the PowerIQ port enables a second device to charge simultaneously.
For iPhone Users
PowerDrive PD 2
PowerDrive PD 2 provides fast charging for iPhone via the USB-C port. Just keep in mind that a USB-C to Lightning cable is required. This is also typically Anker’s least expensive car charger with Power Delivery.
If this buying guide helped you make a purchase decision, please let me know! Also, be sure to tell me what buying guide you would like to see next!
Until then, Power On, Anker fans!
