it does, but you need to trigger the camera’s recording, not livestreaming through the app.
Click on connect and run through the field of view and you will see, it’s connected.
BUT. Without the trigger of a recording, there is no connection to SurveillanceStation. Currently you are ending up with an error message after each recording, stating you lost connection. Else you can not record through surveillance station.
Only if the camera records, you can grab that clip additionally on surveillance station, which is BS.
The camera should be integrated and responsive by NAS and not only the internal 11 second clips…
