I had recorded a video for Bolt when I was testing the bolt, saw similar delays of more than 4-5 seconds, will check if I have the video still with me. Had planned to write a review, then decided not.
Roav Bolt with iOS 10.3.3 on iPhone SE (Review)
After updating the Bolt to version 0.5.16, call routing issue has resolved and it is working as expected
The more I use Bolt the more I miss the media buttons on it.
@AnkerTechnical we need media buttons on Bolt. That will make it an unbeatable product.
I picked up the ROAV Bolt on a recent trip to the US as itâs not currently available in the UK. My experience has been slightly tarnished by the fact that iOS support is very limited and buggy; not quite what I thought would constitute âbetaâ.
Pros:
- No ground loop noise
- iPhone automatically connects every time I get in the car without the need to do anything (my old Anker car dongle required you to push a button every time)
- Call quality is a lot better than my old Anker kit, and the volume is correct - before calls would be much quieter than music playing
Cons:
- Itâs very difficult to tell when something fails because thereâs no cellular reception, as opposed to Assistant not understanding. By which I mean, if thereâs no data connection it fails silently. Coupled with the delay in responding (2-3 seconds) I have to pray itâs doing something every time I talk to it!
- Google assistant can transcribe a text message, and read it back to me but sending fails every time and I have no clue why
- Music playback works fine from my iPhoneâs internal storage but not from Spotify (which is a known limitation)
- The Google assistant app on iOS can search Spotify and display the result, which you have to tap on, but ROAV Bolt does nothing
- Google Assistant cannot play podcasts from internal storage, nor from the web it seems
- Similarly it refuses to play radio stations âYou cannot do this on this deviceâ
- I can trigger Google Maps directions, but they donât come up on the screen even if I unlock it - instead I get notifications on the home screen which I can then tap on
- Despite the more sophisticated mic setup, it is sometimes hit and miss on a motorway whether ROAV Bolt will hear correctly what Iâm saying. Mostly anything that requires multiple responses (e.g. a game) is fairly hopeless
In summary, it does a better job than my previous Anker bluetooth kit for my car but fails miserably on many of the things I hoped it would do. Fingers crossed it can improve.
Thank you for an honest review!!
Some further thoughts:
- The text messaging doesnât work because Google Assistant itself only pastes transcribed text into a message window, it wonât send it (you have to press the button). So if you check the Assistant app after transcribing a message, you can press a button which pushes the text to a message window, but otherwise you wonât see it.
- The Bolt is less functional than using the Google Assistant app with Siri Shortcuts; e.g. using Siri shortcuts I can request navigation to a place, and Google Maps will appear and the navigation will start.
Nice review and pics
@robertcurtis it would be great if you can create a separate post in Product review for Roav and add your details there, this will add credit and do justice to your well thought written review
Yeah, my bolt has a bunch of problems too. Makes me sad
Great review! I had issues setting up the Roav Bolt with iOS 12.3.1 on a MINI Cooper. It took over 30 minutes. I was finally able to get it set up and it works, but not as seamlessly as I was hoping. I will try it on another vehicle and hope it works better. The MINI can be finicky with Bluetoothâs.
