Review of eufy RoboVac 30C by Anker
Exactly. And I’m not complaining that it was included.
Also, I can use Alexa as well…so options are welcomed :grin:
I may have missed it. How’s the run time? How’s the cleaning pattern? Does clean the same spot over and over?
Great review and pictures.
I really love the review I’m looking into getting one myself
Thanks.
I’m getting around 100 minutes which is more than enough time, before it automatically finds it’s way back to the charging base.
Cleaning pattern is random. It doesn’t map my apartment nor have memory but knows it’s way around obstacles and can follow long zig zagged wall panels that I have, table legs and the sort. I have witnessed it clean the same spots again, yes. But when I get home, I always find my apartment spanking clean.
I also tend to empty out the vacuum bin of dirt so that it’s empty for each cleaning.
I recommend it if you’re like lazy me when it comes to vacuuming or if you’d like a robotic maid around the house :sweat_smile:
Best to “aim” at the robot when using the remote.
Sometimes you need to search the robot when he is doing the small 1/2 hour job and stops after somewhere.:grin: not finding the charger in another room.
Nice review and pictures, always wanted one of these!
I like how you did a layout of all the pieces included in the box! Really good review :slight_smile:
I wanted everyone to see what you get.
Thank you :innocent:
Yes a good idea to show the included spare parts as well.
2 extra side brushes an one extra filter.
After using mine for about a 3/4 year the was no need to use the extra parts. :smiley:
Nice review thanks!
really nice review I need one in my life haha :joy:
Hmmmm good to know thank you!
Anytime
Thanks. I needed one too. Cheers to clean floors :innocent:
Never had the chance to use an of the Eufy products but after this review, I may be considering it! I currently have a Roomba basic model and it just bumps around all day. Very well thought out review and wonderful pictures to boot.
You should first consider what type of RoboVac is fitting for you.
I am very happy with that simple version the 11S.
( no app, no magnetic strips, no detailed schedule)
Ideally, something which has features that allow scheduling and remote control. The one that I currently have does the cleaning just fine when I micro-manage it. I would like something maybe a little less high maintenance.
The 11S has a simple schedule via remote.
Everyday the same time.
No exception possible.
Search for the eufy RoboVac here at Anker.com or at Amazon and get one based on your needs & budget.
