Im assuming that the coil is sitting on top of a ceramic plate, this helps distribute th heat away from the coils. Which is what the pack I have now does. The coils are on top of the ceramic plate which adds to the thickness. So I doubt it can be made thinner unless the forgo the ceramic plate it sits on
Anker uses a similar ceramic pad on its power wave charging pad as can be seen below
