Power Bank for Mac Book Pro (Late 2016-mid 2017)
I you are in search of power bank for MacBook Pro, then I would only suggest you to use Anker USB C power bank only with high battery capacity. The Anker PowerCore with a battery capacity of 20100 mAh can charge your MacBook Pro, iPhone and iPad once with a Single charge.
No, that would not be the best choice.
If you absolutely need one right now, then the best option would be PowerCore+ 26800 PD (currently $120). If you want something smaller and cheaper, then PowerCore Speed 20000 PD (currently $70 with coupon), but it will also be slightly slower.
If you can wait, wait… But you might be waiting for a while.
