According to anker’s answer on Amazon it would seem so but might be something that comes later since they say in the current stage
Newest Product in PowerConf Series -- Be an Instant Pro - PowerConf C300
I honestly had to take a moment to figure out what Windows Hello was.
I read that the code should be sent out by the 15th and is good until April 26th so my guess is sometime Wednesday a code will be sent out for those who put their email address
That would be correct my guess is tomorrow or the day after but unlikely today since busy with product launch and all
I am pretty sure the phrasing and overall situation is… poor and it might bite them long term.
Initially the contest was, I believe, 28 prize packs (the one you mentioned) and then 100 prizes for posting workplace fails. At some point prior to the contest concluding they added a workplace hack contest, which also seemed to have 100 winners. After that, winners were seemingly revealed a day early, not a huge deal for the fail contest since that had ended 10+ days prior, with the list you posted. Not only does everything refer to the prize being the kit, with most contest suggesting it’s just a single prize (I even recall the rules listing the odds and most people walking away with a $15 cable, which is better than nothing), the list for the fails and hacks are identical. I know I didn’t actually enter the hacks contest, just fails, so there is something weird going on and I am pretty sure a lot of people are going to be disappointed.
I’m aware thanks
Well, I have thoughts on that actually. (I have thoughts on most things, and my ADHD meds have worn off).
They have have no posted reviews for the 2 most expensive things, and only 1 for the power extend usb-c capsule. Additionally, they have 2 more premium versions the power conf speakerphone.
Next, it has been a while since their last giveaway ~6 months and ~8 months since their last testing.
So what are you thinking? They decided to change the contest because there has been a drought and now they will likely get a bunch of consumer reviews or they just messed up since it has been months since they bothered?
Like, I am fine with a cable, I just would like to prep myself for what is coming. To be perfectly honest, I would just settle for conformation I filled it out correctly. I didn’t get confirmation and there are so many little ways to get rejected with a firm cut off, I’d hate to win and then lose because I wrote AdmiralVic like I usually do, when my name is Admiral_Vic like it is here.
I wouldn’t classify it as they neglected it. I believe the last 13 months has impacted them just as much as any other company. Crazy tech material shortages and unpredictable demand had them intentionally focusing on other things, I assume.
In my experience, I have been a week late filling out the form, and they still accepted it. Previously, I did not receive any notification. The package just showed up.
I may pick up one of these and compare it to the logitech c920, brio and my a5100 with capture card.
I have been Beta testing PowerConf C300 Webcam for quite sometime and just received confirmation I could talk about it, Will plan to have review soon for it.
So it’s your fault?
All the bugs about to be found are because you didn’t find them.
I’m sure they keep sending you beta as they know you don’t leak, but obviously there’s a need for more diversity given how many bugs become obvious in first weeks.
That’s where I read it and am on the lookout for the code
I have a $30 code if someone needs it.
I agree on the Diversity of beta testers, during my testing - have been actively providing inputs, issues faced, and features would have liked. Only so much can be done, since I only use Windows 10 (no more mac for me) tested with 2 laptops and a windows tablet.
For sure, the improvements I had observed and notified have been fixed for PowerConf C300.
Cool, so that means they need to send you one of everything as I’m pretty sure their Q35 will have bugs.
Dang I wish I could beta test as I have a windows laptop a Mac laptop an android phone and an Apple iPad. Congrats on getting to beta test I look forward to your review
I have not been lucky with the Soundcore side of house… i submit the form but nothing comes back , mostly selected for Anker, Nebula and Eufy…
