The sites are never up to date, really.
They are always busy in creating competitions and donating things!
Mystery product in need of answers
Zolo liberty vs liberty air? I always doubt
Which do you prefer? Iāve never used the Zolo Liberty, but I donāt like the designā¦
I personally like the sound and fit of Zolo Liberty. It has a very nice bass response plus it is very comfortable to wear for extended period of time.
But this is very subjectiveā¦
Iām just saying I donāt like the way they look. I have no idea about the quality
What is more important?
The design or the sound?
Of course they should fit.
I just bought these as well today. I looked for ages for a good pair of wireless buds and got confused between these and the Liberty Neo and their $40 difference. I went to Best Buy (because Iām angry with Amazon right now) and tried to price match these. They pointed out the 88 hours of play time difference. I spent about her hour looking for more info on these only to be led here.
So, at this point I think these are probably an Anker&Best Buy only product only sold at best buy and made for best buy.
But they are hella good ear buds. I was thoroughly impressed in the 20 minutes I got to use them today. Iām always surprised by Anker quality. Idk I let them keep doing it to me.
Every time I listen to Liberty Air and Zolo Liberty, I love Zolo Liberty more.
Sound/comfort difference is so huge between the two
I like the way the liberty air look. The design also allows them to stay in my ears better, and gives them expert noise isolation. I havenāt tried the zolo libertyā¦
Zolo liberty stays in ear much better than Liberty Air (but that may be subjective, it works better for me at least).
Yeah, I think it really depends on the user. I like how far Liberty Air go down into my ears. With the rubber eartips, they get an amazing seal and literally will not fall out of my ears. They also block out a lot of noise
I have a pair of these and they have become unpaired. I cannot find a fix for this anywhere as all the information I have been able to find is for the neo and air models and they donāt have the same reset process. If anyone knows how to fix this or has a PDF of the owners manual that would be awesome!
