Flare Video Review!
Nice video review! Does the battery life vary much with the LED toggled off vs if it were on?
(I’m assuming they can be turned off, yes?)
Great review video @joshuad11 Looks a fantastic speaker :smile:
Yes battery life is effected if the lights stay on, but it’s not that drastic of a difference as say when your using two flares paired together.
Yes, they can be turned off :smile:
As far as battery life, I haven’t tested LEDs on vs. off, but I would imagine there is a difference, just not a very significant one.
Keep in mind, Flare+ is launching later this month with longer battery life, better sound, Bluetooth 5.0, and it includes a USB port for charging other devices.
Really?! About how much does that impact battery life?
When two are paired together I have gotten about 5 to 6 hours of use.
Strange… I wonder why it uses that much more battery life.
I wuld assume it’s because of the bluetooth connection to your phone and the same syncing to the other speaker. More power draw to keep it in sync and working together for stereo sound
