Ahh OK, thanks for the reply!
eufyCam E Wireless Security Camera Launch
Got mine today, unboxed and all setup took about 5 minutes! Quick and easy and yes it does have facial recognition. The original battery charge is about 75% so i will leave it plugged in over night. Then I will place outside and dated to see how long the battery will last for. I also ordered a second one, so I will have the orignal cam that came with the base and two EufyCam E.
Discounts should be distributed in the following couple of weeks, please be patient. If you still don’t receive it, you could contact eufy support team for help.
I didn’t expect you to receive it so soon!
Yes, it is.
OK, was confused that some backers received codes and cameras too, and others were left in dark.
But, thanks for the update @AnkerTechnical , will wait for the code to arrive.
got mine, its charging and will be mounted when temp gets above brrr facvtor
We love testing? I hope so
very tempting but think I’ll wait for a better sale or price drop
where this EufyCam E can be bought in Europe - EU ?
Can be expect on the end of March!
Is there an ETA on Google home hub / assistant integration?
Feel free to send some (along with either homebase) over to me
No way bro! … I doubt you want the ugly eufycam E.
You want and need the original eufycam with A.I. Homebase
(Joking aside: As soon as you got the A.I. Homebase you can also add eufycam E additionaly, yes)
wow I like Cam E as well, almost put the trigger.
but checking any other further discount. lol
for notification speed: i m confident on Cam e …faster than 2c…(with AI)
I dont like AI… sending sth to China.?
hope you later tell us the performance of cam E hehe .enjoy
