6 top AirPods alternatives
Because I don’t have to worry about charging them. Also no having to connect through bluetooth. I just find the wired earbuds more convenient really. I like my Galaxy buds but I’m mostly using my wired earbuds
I understand not having to charge them :+1:
Don’t they connect automatically when you take them from the case? I find true wireless to be the most convenient of any earbuds…
Hang on let me check
Huh TIL! Yea as soon as you take them out of the little case they come in, they connect. I guess I just don’t like turning the Bluetooth on :joy:
Lol, if you leave Bluetooth on then that makes them super convenient.
Lol probably so! :sweat_smile:
Question here… Does any of Soundcore True wireless headsets allow use of either of headset ( L or R) independently or only one can be used as Master and other is a slave?
they all use master slave setup. However some of the earbuds still allow you to connect them separately.
Does Neo or Liberty Air support independent usuage of headset?
Only the liberty neo allows for separate use of each earbud, not the liberty air
meh dont like earbuds wreck you ears
They shouldn’t if used properly, and don’t have the volume n bass set too high.
Yeah I still like head phones best though
Thanks, that was the answer I was looking for! Neo are better ones for battery saving and usage.
