Recently I have had an issue popup on my Zolo Liberty+ where the right side has failed to pair with the left side. And just the other day the right side finally just stopped working entirely. I have messaged Anker already as they were a gift and Zolo was unable to help as I have no order number, but have yet to hear back from anyone. So here I am wondering if anyone else has had this problem with their Zolo Liberty+ headphones. These were pretty sick headphones up until the right side gave out under very normal use. And @AnkerOfficial if you could potentially get me steered in the right direction as to a possible solution that would be great!
Zolo Liberty+
Can you change a new phone to test the connection? Or you can also try to clean up the pairing records.
I waiting for your feedback.
I also have not heard back from them. Mine also lost sound kn the right earbud. I have reset, drained the battery and reset again, tried 3 different phones and same thing no sound in right ear
Yes I have tried EVERYTHING before even contacting for help, Its just a guy thing The right side is definitely not working.
I have the feeling that it is an problem of the entire product. I hope you can fix it for the the 2nd generation. I mean many people complained about that problem.
I have a friend who has them and he has had them longer and they are still working fine. So it may be an isolated batch only?
@cava3395 Perhaps the right side needs to apologize to the left side for all the mean things it’s said about it. Counseling is in order.
Hopefully, you and Anker can work it out.
Or the left side is a North Korean spy and took out its right sided counterpart? The world may never know
And I am sure they will make this right! They always do.
Have you heard back from them? I messaged them again the other day but still have yet to hear back. Been almost a week now
Negative
@elmo41683 @cava3395
Our support team will contact you guys to deal with the issue. Please don’t forget to check your email box these days.
Mine are still in the box, haven’t opened them yet. Was waiting for some time when i can maybe do a video but will prob have version 2 out by then the way things are going here lol
I had the same problem, lost of volume in the right unit. Tried everything, then contacted support. They were quick, offered me a refund or a replacement - I was a Kickstarter backer. Choose the refund. Everything was handled with the expected Anker customer support quality.
I’m sorry for you people who have yet to receive a reply. Have patience, I’m sure Anker/Zolo will get to everyone. It seems to be a pretty generalized issue - I actually read about some cases before having it happen to me. I hope they get to the source of the issue and solve it for version 2. Other than this issue, I was loving my Liberty+!
I heard back from Zolo this morning and it looks like I will be getting a replacement. They were great while they worked as I used it continuously up until the volume dropped. Can’t wait to get the new one and starting jamming to some tunes
Me too. Hopefully the replacements last longer than these did. Having to go through this process again would, SUCK
I now have the same thing. Bought it on kickstarter and I’ve been really enjoying using it. Then all of a sudden the earphones disconnected. And I can’t get them to connect to anything now.
In fact, they aren’t discoverable at all.
The right earpiece switches on with the standard whooshing sound and then two low beeps. The LED flashes white sometimes in quick succession and sometimes in slow pulses.
Tried to reset, connect to other devices, drain battery etc etc all to no avail.
They will need replacing. My replacements were gifted to someone so it aint my problem anymore
Try putting them both back into the case, then remove them without pressing the center button. Once both are removed, press the center button on the right and then the left earbud. Go to your phones bluetooth settings and forget all connections and then make sure its discoverable. Once you do that you should be able to pair these to whatever u want
