You could set up a Home Theatre in your home, or you could just turn any flat surface into a Home Theatre. The Oracle projector does that and more. It has Android OS built-in so you can easily navigate through it while pairing other devices through WiFi or Bluetooth. And it fits just about anywhere, from your bag to the palm of your hand.
Designed with a 500 ANSI Lumen bulb and supported by a 0.45 DMD it projects a sharp, colorful and clear image from a 50-inch to a 180-inch surface. But that’s not even the best part! It’s high functionality, 16 GB of internal memory, and many connection ports make it perfect for any occasions by allowing you to connect everything from MacBooks to mice and keyboards; run any apps from Netflix to Microsoft Excel; or screencast or share your device’s screens through Oracle’s massive projected image. And it even has built-in speakers and a 3.5mm audio jack for you to enjoy.
The Oracle really does make the future look brighter, not just because of its powerful bulb, but because what it heralds. A change in how you consume and share your content. Imagine having all of your work presentations on a device you can just put down and start projecting. Or having a home theatre you can bring room-to-room, from the kitchen to the bedroom.
All this from a beautiful, minimalist and ergonomically designed projector for the modern times.
