Hi,I have a Mi Note 10 lite phone
it supports Mi Turbo charging (30 WATT)
I want to buy an Anker power bank but I see lots of features and I’m not sur ife they work for my phone… like Quick Charging and Power Delivery / which make the power bank more expensive
I looked in Quick Charging compatible devices and didn’t find the Mi Note 10 lite, but it’s an old list so I’m not sure…
So should I buy a one that have these futures (would they be faster anyway)? or it won’t have any difference with my phone than normal IQ charging?
Which Power bank should I buy?
So it’s USBC, no mention of any protocols so I’d assume it would only accept 5V 2A 10W.
The typical life of an Anker powerbank is longer than the typical life of a phone, so suggest getting something which has some more power than you can use now.
I’d suggest
https://www.amazon.com/dp/B08LH26PFT
It will recharge with
Thank you, I got a Powercore II as recommended from Anker support team.
I don’t think any powercore supports the Turbo charging (30 watt) but they will still charge your phone, just at a slower speed. So just get whichever powercore you like
