So I have been looking for a charger to use my USB-c to USB-c cable. I first picked up an aukey brick because it was the cheapest but it doesn’t always fast charge or charges its fastest when first plugged in. So I looked around and found Anker 18 watt brick, the dilemma I have is that there is one at best buy that is just power delivery and not iq3 and its 2 dollars cheaper compared to the amazon one. I don’t know the differences if any to these two charges and I’m charging an s10e and some my headphones with it. Can anyone help me with my decision?
Which 18 watt charger to get?
Hi @Miles_Franklin, Power Delivery will charge your Samsung Galaxy S10e just as fast as PowerIQ 3.0, so feel free to go for the cheaper version… Hope this helps!
Since you want to charge those two devices, get one with USB-C and USB-A ports:
Black
https://www.amazon.com/Charger-Anker-Delivery-PowerPort-Indicator/dp/B07GWR9V1N/
White
https://www.amazon.com/Charger-Anker-Delivery-PowerPort-Indicator/dp/B07GWQ2GJC
