Hello!
I am using the anker Powercord 20100mhz and i was looking if there is any other with more juice to have it as backup.
Any ideas guys?
Hello!
Any ideas guys?
26800… if you don’t care about USB-C PD or QC, this is your best option: https://www.amazon.com/dp/B01JIWQPMW/ref=cm_sw_r_cp_tai_.uzcAbXN1W4RG
As @joshuad11 has said, if USB-C and QC are not required the 26800, if you want USB-C PD you would be best going for the 26800+
I need USB C , thats the problem
The 26800+ Model has USB C ? I was looking for it at Amazon and i couldnt find the USB C port
There’s two versions which can make identifying an issue, there’s the PowerCore+ 26800 and then the PowerCore+ 26800 PD;
Wait, so the [quote=“ndalby, post:6, topic:55725”]
PowerCore+ 26800 PD
[/quote]
is EXACTLY to the 20100 type but with 6700 more juice?? in size is still a big brick?
There’s always the powerhouse, but it might be a bit big for the carry-on
jajajaja yes, i was looking for something that can fit my pocket or bag, and upgrade from my 20100
Yeah @ndalby and @joshuad11 are right - definitely 26800. You could also add a slim or something to your 20100 for another 10,000, but then you’d have two batteries to deal with.
No, the PowerCore+ 26800 offers Power Delivery, whereas the PowerCore+ 20100 does not.
Whats power delivery? I have been using my 20100 type c for at least 1 year and is great! The only problem is that its takes 6+hs to refuel.
Have you tried charging it up with a fast charger of sorts? I have a powercore II 20k and if I use my Samsung fast charger it charges fully in under 3 hours
Yeah the power delivery will allow for faster recharge, and it can charge some laptops closer to full speed.
That power delivery is 30w if I’m not mistaken - even though some of the USB-C manufacturers are getting squirrelly and putting in 45w charging (Acer R13 for instance)
Indeed and Anker is doing 45W soon on their PowerCore+ II 20000!
I use the same brick with type c that i use for my nexus 6p. I believe is fast chargin, since using it with my phone will have it full in 1.5 hours vs 6hs with normal cable and brick
Sorry I meant have you tried charging the powercore with a fast charger, you said it takes a long time for it to charge fully. But for me mine charges rather quick given its size
The PowerCore II 20000 support fast charging, but the PowerCore+ 20100 just supports a 5V 2.4A input.
Ahh, I did not know the 20100 doesn’t support fast charging. Good to know that the one I have does at least. Sorry @ImperialCactus I was hoping that you could take advantage of that but I was mistaken. My apologies
