What is the absolute best anker lighting cable I can get
I recently broke my powerline+ii and I want to replace it what is the best lighting cable I can get
https://www.amazon.com/Anker-Powerline-Lightning-Charger-Certified/dp/B07Q611G3S/ref=mp_s_a_1_14?dchild=1&keywords=anker+lightning+cable&qid=1600039605&sprefix=anker+l&sr=8-14
You can go wrong with this cable
This is the best Anker Lightning cable
, Anker Powerline+ III Lightning to USB A Cable, (3ft MFi Certified), USB Charging/Sync Lightning Cord Compatible with iPhone 11 / Xs MAX/XR/X / 8/7 / AirPods, iPad and More
And this one top notch, Gold USB-C to Lightning(collector’s item) :sunglasses:
Anker 2020 Special Edition 24K Gold USB C to Lightning Cable (6 ft) Powerline+ III, MFi Certified Lightning Cable for iPhone SE / 11/11 Pro / 11 Pro Max/X/XR/XS Max, Supports Power Delivery
https://www.amazon.com/dp/B086KVCTFM/
Please mark this thread as resolved if this helps you!
PowerLine+ III USB-C to Lightning (35,000 bends, rated 4.8 :star:)
Thank you do you know what the best brick is to match it
Would you like a dual port charger so that you can charge another device simultaneously? If so, what devices might you want to charge?
Im looking for something I can get the most functionality out of
PowerPort Atom III (2 Ports) is a good option, providing upto 2 ports - USB-C (PD) as well as USB-A, and up to 60W.
At a minimum, provides 2 ports, USB-A / USB-C, PowerIQ ports… should be good for most functionality… :wink:
then there are a lot of other options based on what you need for!!
In order to help, I need to know what devices you are wanting to charge.
Which one did you pick OP?
Originally @gwstarkey.gws had made up mind to get powerline+ III
Same has been suggested above… Now matter of time before he buys it
Definitely this one if you wanna look good.
Look rich** :joy:
Is it made from gold ?
Yes it is and it is like a hundred dollars.
Yup the ends are gold coated and is sold for $99.99
