[US] PowerExpand Direct 8-in-2, ONLY $59.99!
Anker’s PowerExpand Direct 8-in-2 is on sale for just $59.99 with code AKUSBC47.
Order from Amazon
Note: You are paying more for the Lightning audio port. If you don’t care about this feature, note that PowerExpand Direct 7-in-2 is on sale for just $53.99 with the clippable coupon.
Features & details
  • The Anker Advantage: Join the 55 million+ powered by our leading technology.
  • Massive Expansion: Expand your MacBook’s 2 USB-C ports into 1 Thunderbolt USB-C port, 1 USB-C data port, 2 USB-A ports, 1 HDMI port, 1 SD card slot, 1 microSD card slot, and a Lightning audio port—all from one ultra-compact hub.
  • High-Speed, High-Def: A Thunderbolt 3-enabled USB-C port supports huge charging power up to 100W, data transfer up to an astounding 40 Gb/s, and media display at resolutions up to 5K, while the Lightning audio port supports maximum 48 kHz/24-bit digital transmission.
  • Multi-Monitor Display: The HDMI port supports a resolution of 4K@30Hz while the Thunderbolt 3 port supports 5K@60Hz. Connect to both simultaneously to enjoy crystal-clear streaming or mirroring across 2 displays.
  • What You Get: PowerExpand Direct 8-in-2 USB-C PD Media Hub, travel pouch, welcome guide, worry-free 18-month warranty, and friendly customer service.
Not for me but a good sale :+1:
Thanks for sharing! :ok_hand:
Thanks for sharing
