When will there be a firmware update available for the Wakey ? Regarding the issue with brightness…
Thanks
Thanks
What issue are you having?
The brightness is too high, even in the lowest level. I know that I can turn it off, but thats not the solution.
agreed, it would be nice to have the brightness level available to be turned down lower.
Is nobody from Soundcore / Anker here ?
Have you tried using the Soundcore app? Maybe there is a setting for it there
Of course I used the soundcore app…
