UK £80 Off Robovac 15C Max Amazon Voucher Deal
Ok, so thers a voucher available on the smart Robovac taking it down to £160, it’s lowest price on Amazon.co.uk.
Nice find for some help around the house.
Reminds me “old Willy” has to work now.
Enjoy the week Paul, relaxing at work from the vacations!:laughing:
I’ll relax ant work while Mary is busy at home
She will soon need one of her small brush gears replaced soon. Things are getting a bit grinding.
I did a replace of the motor unit.
After opening I saw the gear inside was absolutely worn out.
You will need Charlie to help,
Small fingers are the best for taking off the tiny plugs. :laughing:
There is a video:
But never do handle the screws like this "… " does.
Never an engineer.
That’s a good deal for anyone wanting to try a Robovac!!
I’ve got the basic model 15C and it’s still going great - it’s had a bit of a rest over the Summer with the kids being home and them leaving stuff around - but I’ll get it into it’s normal routine again as they return to school this week!
Thanks for that Franz.
I’ll find the parts and watch the video :+1:t2:
Same here Fiona.
Ours has had a bit of a break but has now started normal service. 9.30am daily :+1:t2:
The gears are not offered, its the whole motor. :roll_eyes:
After “surgery” I opened the transmission case of the motor and found that rotten nylon gear.
This could be replaced of course, but where to find…
Maybe the gears are plastic to create a deliberate weak point to protect more expensive or delicate parts.
But if you can’t buy the gears that’s poor.
When I dismantle I will search the Internet for an equivalent, I’m sure they exist out there somewhere :thinking:
Yes they exist somewhere.
Standardized parts of course.
But not sure you can buy only a single one.
