I would like to transmit audio from my Samsung TV to apple iMac. Do you know if an iMac can receive audio via bluetooth from your device?
I’m not sure this is supported by Apple (receiving audio via bluetooth), so I’m asking your support before buying
Transmit Audio from Anker Soundsync A3341 to iMac
Hi @francescofalconi , I’ve tested this using my iMac & A3341 and you are not able to pair the A3341 to a Mac in transmit mode (for incoming audio) as the Mac will not detect it on BT, only receiver mode allows the Mac to detect the A3341 (ie audio outbound from iMac)
Was there a particular reason why you wanted to?
