Hi all,
I’m a happy and proud owner of my Zolo Liberty and i’m writing for a friend (he doesn’t really know English) who purchased the same earbuds after seen mines.
He has a issue on the charging case. Once recharged all the three lights are off, and that’s ok. But if he opens the case or just move it in order to switch them on and check the charge, the lights won’t turn off automatically, they stays on for days. The only way to shut them off is to connect the case for charge and then disconnect.
Is there something we can do to solve it or do they have a problem and it’s better to ask for a change?
Thank you very much!!
