I just purchased the trance and I already own the flare2. Are these two models able to be synced to play at the same time?
Syncing Trance with Flare2
You cannot pair Trance and Flare 2 together
As @Shivam_Shah mentions @LeeLee2
To add, you can only pair the same model speakers providing they were designed to pair.
Only the identical model can pair with TWS , or if they all have Partycast.
The Trance has TWS so you’d need two Trance to make existing work as a pair.
The Flare 2 has Partycast, so you’d need another Flare 2 or another speaker supporting Partycast.
Or you can use a bluetooth dual something in between, e.g.
