The siren of my eufyCam setup sounded during a longer power outage (3AM…). I could not connect the app, since the WiFi router was out as well.
Is there any way to silence the alarm in such situation? Is there a way to access cams and HomeBase directly? Is there a way to set the max duration of alarms?
By the way, why was the alarm sounded because of an outage? Did HomeBase go down after a while and then did cameras panic? I and my neighbors would be glad to be able to prevent this behavior.
Thanks.
