I need to power a small motorized device (a low-power travel CPAP machine) for about 6 hours continuously for 1 or more nights.
The supplied CPAP device includes a power adapter. I will connect my Anker battery to this adapter; then the adapter will power the device - like this:
(Anker Battery - model:?)–> ( Adapter - specs Input: 13.5V, 5.5A ; Output: 19.2V, 2.6 A ) --> cpap_device
I would like something like 5 amp hours or more. In the past I have used a deep-cycle lead-acid battery to serve this need.
Which type of Anker battery should I be looking at to meet the above specs in the 5 amp hour range?
Thank you.
-e
