Soundcore Sport Xl USB port broke
Hi there,
Lastnight in a party someone broke the usb charger port of my Soundcore Sport Xl. I tried to open it, but there is any scrw. Is there a way to fix it?
Regards!
Can you send a picture of the inside of the port. If the part inside is broken it is extremely ill advised to try and fix it. You might break something else or injure yourself. You can tech it to a tech repair shop where they might be able to help you. Or you could get a new speaker.
If you sign up on Soundcore’s website here you can get good discounts on new speakers. The flare 2 is a great speaker and I highly recommend it.
