Hi - the sound on these headphones has faded - max volume very quiet. Same on you of all devices we’ve paired with. So assuming it’s the headphones. Have tried a reset but same after. Anyone any ideas. The headphones are new only bought in January
Soundcore Spirit X volume control
Have you tried giving them a clean with some rubbing alcohol to make sure no wax and the like has built up in the mesh?
As you are still within your warranty and a clean fails to resolve I would suggest reaching out to service@soundcore.com with the issue and troubleshooting steps you’ve taken.
We are sorry to hear your headphones are not working properly. According to the information you described, the issue you are experiencing is very unusual.
