Hello everyone, today I would like to take the time to talk about the Wireless Earphones SOUNDCORE SPIRIT SWEATGUARD that I received for testing as power user.
the headphones come in a small box with its characteristic colors of the brand, with an illustrative image quite attractive
Inside this box, come two small boxes in which are distributed in one earphone and case and in the other its accessories and user manual
the headphones look very good, with rigid material in the controls, the flexifle cable, and the heads of the headphones are magnetizable, I liked that a lot, because I think they are quite useful when it comes to wearing them around your neck without you having to worry about losing them
It is easy and simple to connect with the phone, once the headset is turned on, you just have to activate the Bluetooth and establish the connection.
the quality of the sound is enveloping, quite good, it sounds great !! I liked it a lot, I’ve played several music, some of them were: look what you made me, heathens, and other similar
The headphones come with the “sweatguard technology”, which makes it resistant to water immersion. I decided to perform a test, I admit that I was afraid to do it because I did not want to lose the headphones, even so I did it and the result was good, the headphones continued working perfectly, the sound quality has been maintained
next week I will perform an extreme test, I will test it during the swimming, and I will see how it works, and about it, I will update my review.
I can only say that it is an excellent headset, I recommend it to anyone who wants good resistance to water, based on the test I have done.
