Okay so I got the speaker a couple of weeks ago and generally I am very happy with the product.
But I have this issue that’s happened a few times now and specially today I can’t get it to work at all.
My setup:
- Speaker is plugged by USB so it’s 100% battery
- Auto shutdown feature is off via app
- The only BT device in my home is my phone, which I am using to connect to the speaker and play music through Spotify
- The firmware is up to date
- I have not done anything strange to the speaker. No drops, no testing the water resistance by throwing it off board, nothing
- I use Android 10, the app is installed, yadda yadda
- The phone is also at 80%+ battery
- This happens when I use a different Android phone, too
Well the speaker works great sometimes and other times, like right now, decides to randomly disconnect from my phone. I am able to reconnect and keep going but it will fail again after 30 seconds or so. Sometimes I will NOT be able to reconnect at all so I get off my couch, reboot the speaker, connect again… Only for it to fail 30 seconds later anyway.
I have used cheap 20€ speakers and never had any issues like these. I don’t know what to do about this but man this is a big waste of time for me and I might just return it.
