Hi
I have a SoundCore Mini and bought a ScanDisk Ultra 32GB MicroSDHC UHS-I Card to use in it. I plugged the card into the speaker and connected it to my Mac to download the songs but my Mac does not recognise the disk. Any idea what’s up?
Thanks
SoundCore Mini and MicroSDHC UHS-I Card
Did you format it to fat32?
Then you should feed the card with the music you like directly from the source in mp3-format.
Dont know if this is possible with ITUNES (MAC).
I f successful, You may see if there are some songs (mp3) on this card you can use it with that Mini.
@ricjc You won’t be able to download from your Mac to the speaker directly, the microSD card will need to be physically connected to the mac to transfer music, using either a suitable card reader / adapter.
Also as mentioned the format needs to be FAT standard and mp3 audio format.
Thanks for the advice. I will try the format and get a card reader…
