Soundcore Liberty Air not turning on
Hi,
I bought a pair of Liberty Air earphones several months ago but never used them.
I let them charge all night long and now the 3 leds on the case are turned on.
On the earphones, however, no LEDs light up, neither when they are inside the case, nor when I take them out of the case.
I cannot pair them with the phone because they do not appear in the list of Bluetooth devices.
I also tried the reset procedure but they do not show any signs of life.
What can I do?
Make sure that the plastic covers for the charging pins did not get dislodged inside the case blocking connection
Thanks for the reply.
No plastic cover is present on the charging pins
