SoundCore Liberty Air 2 with Xiaomi Note 10Pro
Hello Guys,
Could there be an issue with SoundCore Liberty Air 2 and Xiaomi Note 10 pro? The bud works perfectly with music on and for the Call the bud the other party are not hearing very clearly and it works perfectly with other phones, just for the Xiaomi Note 10 pro.
Any advice on that?
Nose around in Developer Mode bluetooth codec settings. You may be using a bad codec.
Also worthwhile delete pairing, Reset buds, disable bluetooth, delete bluetooth cache (settings, apps, system, bluetooth, force stop, storage, delete cache) , reboot, enable bluetooth Pair.
