Soundcore infinity mini Soundbar review english and german
english review
The soundbar was delivered to me in a very short time.
delivery
The package typically includes a lot of useful accessories like an aux cable, an optical audio cable, a remote control, a manual, the power supply and even a wall mount. So pretty much every application is taken care of. This is my first soundbar. The installation is very simple, so that you understand everything even without instructions.
Optics and processing:
The soundbar has no manufacturing defects, looks very chic and can be easily installed in almost any location thanks to its small size. The housing is made of plastic.
functionality
The soundbar is powered by a power adapter and can be used as a Bluetooth speaker as well as with an Aux or an optical audio cable. The remote control has a movie and a music mode that optimizes the sound for each selection.
sound Quality
The soundbar has a clear sound and can be used for movies. (Best in combination with a subwoofer, but I can not recommend it for music, as the bass just can not perform well because the volume of the soundbar is simply too small.
Price-performance
For a price of 76 € the Soundbar is worth its money, as comparable products are significantly more expensive and usually offer poorer sound quality.
Improvement would be a turn-off standby LED. Unfortunately the LED of the Soundbar can not be switched off. In addition, I would prefer a matte case, since a piano lacquer look is usually very sensitive to scratches.
Deutsche Rezension
Die Soundbar wurde mir innerhalb sehr kurzer Zeit geliefert.
Lieferumfang
Im Paket ist Anker typisch sehr viel nützliches Zubehör enthalten wie ein Aux Kabel, einem optischen Audio Kabel, eine Fernbedienung, einer Anleitung, das Netzteil und sogar einer Wandhalterung. Für ziemlich jede Anwendung ist also gesorgt. Dies ist meine erste Soundbar. Die Installation ist sehr einfach, sodass man auch ohne Anleitung alles versteht.
Optik und Verarbeitung:
Die Soundbar hat keinerlei Verarbeitungsmängel, sieht sehr schick aus und kann dank ihrer geringen Größe problemlos an fast jeden beliebigen Ort installiert werden. Das Gehäuse besteht aus Plastik.
Funktionalität
Die Soundbar wird per Netzteil betrieben und kann sowohl als Bluetooth Lautsprecher als auch mit einem Aux- bzw. einem optischen Audio Kabel genutzt werden. Die Fernbedienung hat einen Film- und einen Musik Modus der den Klang fĂĽr die jeweilige Auswahl optimiert.
Tonqualität
Die Soundbar hat einen klaren Sound und kann super fĂĽr Filme genutzt werden. (Am besten in Verbindung mit einem Subwoofer. FĂĽr Musik kann ich sie jedoch nicht empfehlen, da hier einfach der Bass nicht genug Leistung bringen kann, da das Volumen der Soundbar einfach zu klein ist.
Preis- Leistung
Für einen Preis von 76 € ist die Soundbar ihr Geld wert, da vergleichbare Produkte deutlich teurer sind und meist schlechtere Tonqualität bieten.
Verbesserungswürdig wäre eine abschaltbare Standby LED. Die LED der Soundbar kann nämlich leider nicht abgeschaltet werden. Zusätzlich würde ich ein mattes Gehäuse bevorzugen, da eine Klavierlack Optik meist sehr empfindlich für Kratzer ist.
wow!! great review! good job!
Good review but please include some pictures (if possible)
Great review! Thank you for sharing in two different languages! Would love to see some pictures though!
Thanks for the bilingual review Brad
