Disclaimer: This review was written as part of the We Love Testing program here.
Product Links
Well guys despite a bit of bad throat I’ve finally managed to finish off my review for the SoundCore Infini. Thanks to @AnkerOfficial for the opportunity to have a mess with this beast of a speaker, just need to get it wall mounted once TV has been moved (again)
Key Features
- Integrated 2.1 Channel Soundbar: Infini is equipped with 2 tweeters, 2 built-in subwoofers & bass ports to deliver a immersive cinema experience.
- Huge Hit of Bass: Low frequencies are enhanced in real time by exclusive BassUp technology for deeper, intensified bass.
- Customized Acoustics: Extended 35’’ design is optimized to deliver the same stunning sound whether wall mounted or placed in front of your TV.
- Input Options: Optical, digital coaxial, or AUX connections. Ability to stream wirelessly via Bluetooth
- Optimized Audio: Use Infini’s remote control to switch between music, movie, and dialogue modes to tailor the sound output to your entertainment.
The Good
- Powerful with very good bass and overall tone
- Retains audio level after power off (sounded the same loudness
, see meaning below)
- Solid build
- Sleek black metal mesh design that would fit with any environment & keeps cleaning easy
- Ability to wall mount with included kit, or to be able to use flat without impeding TV view
- Plethora of connection options for devices - BT, Optical, RCA to 3.5mm & Digital Coax
The Not So Good
- Price, depending on region, is a tad above other ‘non-premium’ competitors (the likes of Bose, Sonos)
- Equalizer settings - in Movie mode background sounds overpower present dialogue, Dialogue mode sounds a tad tinny
- Lack of ability to see your current audio volume level / percentage, only if you have hit minimum or maximum completely
