Disclaimer: This review was made as part of the We Love Testing program here.
The Impressive
- Improved audio & bass over the first generation Soundcore Flare
- More LED lights, with better clarity & brightness over the first gen model
- USB-C charging port, backing those after a single cable solution
- Like for like battery life against the original Flareā¦that seems to go on and onā¦
- App control of features including remote power down
- Customisable equaliser via the SoundCore App
- Ability to pair with another Soundcore Flare 2ā¦or a few dozen with PartyCast (and enough money)
- Water resistance - good for life accidents or your need to torture a speaker
Slightly Disappointing
- Loss of the auxiliary port, which helps for troubleshooting speaker issues sometimes
- Lack of backwards pairing compatibility with the original Soundcore Flare
- Reduced IPX rating
Learn More here:
