I’ve had my soundcore boost for a couple of years now and it’s worked great. Somehow I managed to over press the power button or something like that and it’s stuck with a blue flashing power light in pairing mode. I’ve removed the connection from my phone (Pixel 4 XL) and tried a soft reset but nothing seems to work. Any suggestions would be appreciated
Soundcore Boost stuck in pairing mode
Hey @Mike_Van_Horn
Great speaker, i have one myself.
You can try a soft reset by holding the power button for 4-5 seconds or a hard reset by holdibgbthe power and bassup button for 4-5 seconds.
Keep us updated on your progress.
A reset as @paulstevenewing mentioned could help.
If it really physically “stucks” you could try to use contact spray to loosen it.
Diagnosis from far distance is difficult.
