Soundcore 2 annoying startup shutdown paired sounds
Would it be possible to update SC2 speaker with less annoying startup/shutdown/paired sounds? 3 different short tones/beeps instead current annoying sounds. I’m sure it can be easily updated in firmware.
Hey @cl4s2013
I own the Boost and Wakey and i also find the noises annoying, more so on the Wakey.
If i need to change alarm time during the night the noises wakes my other half.
Not possible, you should get used to it.
I know life is hard! :smile:
If you have soundcore space NC , you could put those on your other half so they won’t hear it. lolol
Good thinking, like it!
