Is there a way to view the battery level of SoundBuds in Windows 10?
SoundBuds Slim Battery Level in Windows 10
This feature for any bluetooth device connected to windows 10 can only be viewed if you have access to windows 10 redstone 5 which is only available to those with insider access. Otherwise as it stands now it’s not possible, you can try to go to Settings > Devices > Bluetooth & other devices Settings and see if it shows battery level for any connected bluetooth device
I looked into this a while ago and as @elmo41683 you have to Windows 10 Redstone 5. I’m looking into a work around but I don’t think there is a way yet.
@leftov Thanks for asking. Kindly note the battery level can’t be viewed in Windows 10 at the moment. For more discussion, please contact support@anker.com. Many thanks.
