Simple question:
Are the Comply Foam Tips compatible with the Soundbuds Slim?
Simple question:
I have a pair of the t-200’s and just tried them with the Soundbuds Slim. It was a tight fit but I was able to get them on. I would think they would not work too good for on/off application but if you are leaving them on they will work great. The t-300 may be a bit too big of a hole and may fall off but I don’t have any to confirm. Hope this helps
