Some form of right angle USB C PD cable to USB C cable
Things id like to see available from Anker…
Some sort of right angle solution for USB C PD… Having USB C/TB 4 connectors on one side of the device tends to cause stress on the cable… Pretty sure ill have to replace my MBP M1 power cable at some point due to this…
The option for some high grade USB C to USB C or USB C to QC 3 with a silicone jacket… Actually have a soldering iron that uses USB C where its a heat advantage but the other benefit is how flexible the cable is…
Good idea :+1:
