Small/light USB-C PD power bank?
What is the smallest/lightest USB-C power bank? counting grams for the pack.
From Anker it’d be the PowerCore 10000 PD, PowerCore 10000 PD Redux, and possibly PowerCore 10000 PD+. The first two are ~6.8 oz, the third should be the same.
If you want to look at even lighter options check out 5,000mAh options. I note weight on my master power bank list.
Great chart thank you! I think my Galaxy S10+ only supports 15w charging, fast charging a plus.
I have an Anker 10000PD that is too heavy since I am counting grams on my walks.
smaller 5000mAh is okay, using for hiking the Camino and always have AC at the end of the day.
I’d like the smallest lightest 2-port wall charger, and not carry any Micro-USB cables!
