Skygo on Capsule Max
Hi all,
after installing the Google Play version I’ve been able to install and use most of my apps with the exception of SkyGo.
Everything went well during installation of SkyGo and setup with my account but when I started to watch a movie (either live or on demand) after a couple of seconds the screen went very poor like a transparent white window.
Movies can still be seen but with a very poor quality.
Any hint?
Thanks in Advance,
Sandro
Hi there,
Regarding the issue mentioned, we would appreciate if you could contact our support team at support@seenebula.com to provide us a short video to display the issue. We will test out and help you further. Thank you!
Anker Support Team
hello! would you be so kind to share how did you get Sky Go on the Nebula? Because I can’t find their app on the google play in the projector…
Hi, can it be you forgot to install the latest firmware from Nebula?
I still use it, gets updates and so on so it has to be on the store.
no it is all up to date. Which Sky Go did oyu install? From which country?
Italy, I installed the only one available in my country
that is the one I look for… but when I type SkyGo on the Google Play search bar, it doesn’t come up…!
Here’s what I get searching for “Sky go” (with the space).
I don’t get it, maybe because I have a Nebula cosmos Max?! I will check with @AnkerSupport
might be…
Capsule Max is Android 8.1
The Cosmos Max is a different product with different OS, Android TV 9.0
So tricks on one likely won’t work on the other.
Anker has a habit of using similar names for very different products. :thinking:
Hi, I have the capsule max and engaged heavily with customer service before the purchase as I had the exact same need of sky go for our motorhome. This information is several months old now since I bought mines
So, the max is Android versus other products being android TV, the google playstore for access to sky go needs to be unlocked.
Upon purchase you contact customer service, you do an upgrade and confirm the system version via a ticket, you are then added to a ‘beta test’ program and given a password for a download and a special sequence to access the file.
When all is done the version should be V2.0.1042. and you’ll have sky go via the google playstore.
Again, I bought this several months ago so this may now be the standard version, but confirm as other poster that I’ve had several app updates, in fact just tonight.
Hope this helps, create a ticket on their system and you’ll get great help
Jason
